Disco51Pete Posted June 16, 2009 Share Posted June 16, 2009 The srs light has come up on the wifes td4 02plate freelander, i have checked the seat belt pre-tensioners and wiggled them about abit as this regulary happens on my td5 disco from people with big feet kicking the connector blocks, but hasnt made the light go out which normally works on the disco. So any ideas would be great as not worth £50 to get it plugged in for a trivial thing. P.s. it hasnt had a bump or anything like that, the light just appeared other day. Many Thanks. Pete. Quote Link to comment Share on other sites More sharing options...
mayanbilly Posted June 16, 2009 Share Posted June 16, 2009 The srs light has come up on the wifes td4 02plate freelander, i have checked the seat belt pre-tensioners and wiggled them about abit as this regulary happens on my td5 disco from people with big feet kicking the connector blocks, but hasnt made the light go out which normally works on the disco. So any ideas would be great as not worth £50 to get it plugged in for a trivial thing. P.s. it hasnt had a bump or anything like that, the light just appeared other day. Many Thanks. Pet Hi Pete,the same thing happened to my 02 Freelander and it was defininely the connector blocks under the passenger seat that had come undone.. mayanbilly good luck Quote Link to comment Share on other sites More sharing options...
