mpb Posted June 17, 2009 Share Posted June 17, 2009 I have started planning the install of my mud dash. Im trying to work out how to wire my rear wash/wipe up. For the washer I was going to use an off/mom switch to operate the pump. This should be the green wire to pin 2 & black/green wire to pin 3. Then i was going to use an on/on to power the motor & park switch. This should be the green wire to pin 3, the brown/green to pin 1 and the red/green to pin 2. For the carling pin outs look here http://www.mudstuff.co.uk/Fitting_Instruct...itch_wiring_PDF[1].pdf Can anyone see why this will not work. Many thanks Quote Link to comment Share on other sites More sharing options...
cieranc Posted June 17, 2009 Share Posted June 17, 2009 There's a pretty wide range of switches available, is there none that can power all the functions of the beday in one switch? Quote Link to comment Share on other sites More sharing options...
