Guest DiscoTD4 Posted June 19, 2009 Share Posted June 19, 2009 Morning - just a quick query to confirm if my lift pump is working as expected. TDi300 EDC 97 model: If I turn the engine over to get the cam in the appropriate position to allow the lift pump priming lever to do it's thing, I find I only get about 1/2" stroke resistance on the primer lever. Does this seem about right or should I be able to get a good long pump ? Cheers Quote Link to comment Share on other sites More sharing options...
StreetDragster Posted June 19, 2009 Share Posted June 19, 2009 Which way you pulling the lever? On my non EDC 300TDi, upwards (which for my car was the wrong way) was around 1/2" travel, but down and towards the engine was a full sweep and i could feel the fuel pumping Thanks Matt Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted June 19, 2009 Share Posted June 19, 2009 Which way you pulling the lever?On my non EDC 300TDi, upwards (which for my car was the wrong way) was around 1/2" travel, but down and towards the engine was a full sweep and i could feel the fuel pumping Thanks Matt Hi - thanks for the info, on mine it only goes one way which is down. In the up position it clips into place to hold the lever. Cheers Quote Link to comment Share on other sites More sharing options...
