nickjaxe Posted June 24, 2009 Share Posted June 24, 2009 Hi all I need to re-fit the flywheel housing on my 200tdi engine, I was wondering if the big gasket that goes between the flywheel housing and the engine block should have some sealant on before fitting, I do have a new gen parts gasket and it has what maybe but not sure what looks to be a blue line of is it sealant on both sides???????? Same question for the rocker cover gasket as well does that need any. Nick. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 24, 2009 Share Posted June 24, 2009 New, good quality gaskets should be fine on their own. Of course - if you're a little paranoid............ Les. Quote Link to comment Share on other sites More sharing options...
