rhydgte Posted July 20, 2009 Share Posted July 20, 2009 My mates 1993 200TDi has developed a problem which he has asked for my help to sort out, basically as far as I can tell something electrical is burning when driving the vehicle. He has had white smoke coming from the heater vents inside, the passenger foot well and also from the bonnet near the windscreen. It stinks of that electrical smoldering type smell. Where's the best place to start with this then?? Cheers P.S The vehicle is not being driven until we've sorted it. Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 20, 2009 Share Posted July 20, 2009 My mates 1993 200TDi has developed a problem which he has asked for my help to sort out, basically as far as I can tell something electrical is burning when driving the vehicle.He has had white smoke coming from the heater vents inside, the passenger foot well and also from the bonnet near the windscreen. It stinks of that electrical smoldering type smell. Where's the best place to start with this then?? Cheers P.S The vehicle is not being driven until we've sorted it. I'd start with a fuel leak onto the exhaust manifold or the engine earth strap is broken causing the handbrake cable to carry the starter current. Second choices would be a hole in the exhaust or runaway glow plugs. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 20, 2009 Share Posted July 20, 2009 seen as you dont seem to point to it coming from the engine bay, and its all centered around the dash, i suspect the heater blower motor or related equipment. Especially as it sucks its air in from the scuttle panel where you can see smoke, and its coming out of the vents. Quote Link to comment Share on other sites More sharing options...
rhydgte Posted July 22, 2009 Author Share Posted July 22, 2009 Stripped loads of the dash out and after thorough investigations it turned out to be the head unit. It had been bodged in badly by the previous owner! Quote Link to comment Share on other sites More sharing options...
