SPendrey Posted July 28, 2009 Share Posted July 28, 2009 Well, I'm confused. One of the rear doors wouldn't unlock every time I used the central locking remote, so I figured the lock spring had gone (having read around the forum). I bought a new set (all 5), and attempted to replace just the one on the faulty door which had broken into small fragments! In the end I got really fed up trying to squeeze the spring into such a tight spot that I concluded I could live with a door that doesn't unlock... then I find it works fine without the spring! So, what are they for? Scott Quote Link to comment Share on other sites More sharing options...
d1scv Posted July 29, 2009 Share Posted July 29, 2009 Scott, So far as I recall, the springs stop the door relocking itself when you try to open the door. Yes, fitting the new spring is a mission- but it really is easy once you've mastered it. Tony Quote Link to comment Share on other sites More sharing options...
