borojp Posted August 5, 2009 Share Posted August 5, 2009 Hi, Was wondering if anybody could help please? The three lights are on my dashboard on T/C, ABS and Hill Descent. I've been told this could be the brake sensor. Does anybody know how to change this please. Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 5, 2009 Share Posted August 5, 2009 Hi, Was wondering if anybody could help please? The three lights are on my dashboard on T/C, ABS and Hill Descent. I've been told this could be the brake sensor. Does anybody know how to change this please. Bottom of this thread: Link 1 It has some advice, but there'll be an expert along shortly ... Quote Link to comment Share on other sites More sharing options...
borojp Posted August 6, 2009 Author Share Posted August 6, 2009 Bottom of this thread:Link 1 It has some advice, but there'll be an expert along shortly ... Cheers, Thanks for that, garage said it was drivers side front, and will cost £350 to fix by them. If it's not to tricky would rather do myself. Is it straight forward? Cheers Quote Link to comment Share on other sites More sharing options...
rustymark Posted August 9, 2009 Share Posted August 9, 2009 what model / year? Before the 'facelift' the FL used a standard wabco sensor but with a different plug on the end. I have changed both rear sensors on my TD4 2000 def not as simple as RAVE or Haynes say. They seize in place. Front ones also are a push fit but will prob be seized too. As an indication removing my rear ones ended up removing rear drive shafts - you will need a BIG torque wrench! That sais its do-able. Depends on the time you have and tools. One final word - if u DIY then don't buy a genuine LR sensor. Go to a truck part specialist and ask them to show you wabco sensors. you'll find them the same but choose cable length and you may have to cut and splice the original LR plug on - typical cost c£50 opposed to £240 for gen bit....... Quote Link to comment Share on other sites More sharing options...
