Marco Posted August 28, 2009 Share Posted August 28, 2009 Hi, Trying to fix some leaks.... this one is the front differential pan. Are there any 'temporary' sollutions to fix such a leak? Best would be a new diff pan or axle casing but right now I do not have to the time to start such a project... Will sealant do? Steel Putty? Any advice welcome. Cheers Marco Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 28, 2009 Share Posted August 28, 2009 Hi, Trying to fix some leaks.... this one is the front differential pan. Are there any 'temporary' sollutions to fix such a leak? Best would be a new diff pan or axle casing but right now I do not have to the time to start such a project... Will sealant do? Steel Putty? Any advice welcome. Cheers Marco It looks like the weld or metal near it has craked - you're going to have to drain it to do anything, so why not weld it? It's only a tiny ikkle hole ... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 28, 2009 Share Posted August 28, 2009 Degrease it thoroughly, scuff it with sandpaper, then chemical metal or similar to seal it. Les. Quote Link to comment Share on other sites More sharing options...
Marco Posted August 28, 2009 Author Share Posted August 28, 2009 Thanks, at this stage I will probably try to seal it first, I'm a bit afraid to weld it as there are some signs of previous welding job(s). Not sure about the thickness of the metal and a bit afraid of welding a bigger hole into it. I've found the post on replacing the pan on this forum, probably try that at a later stage. Cheers Marco Quote Link to comment Share on other sites More sharing options...
cieranc Posted August 28, 2009 Share Posted August 28, 2009 I was suprised how thin my diff pan was, almost paper thin! The difficulty was trying to weld it up, a mig would have just blown it to bits even on its lowest setting. So I gas welded it, even then I was chasing holes for a while. Beware of using chemical metal too, if you smudge it through any holes, it'll set and then you'll have blobs of solids floating round in the diff oil. I also used a gas bottle as a repair: http://www.landroveraddict.com/smf/index.php?topic=376158.0 It could have been done in situ, but I already had a box of accumulated bits to rebuild the swivels and brakes, so I took the axle out and built it all up on the bench. Quote Link to comment Share on other sites More sharing options...
