peterdon Posted August 30, 2009 Share Posted August 30, 2009 I collected my MY95 Disco 3.9 V8 yesterday. Had a 100 mile journey home. Everything was fine except the temp gauge doesn't work. Water is Ok so no probs there. I assume the sender is at the thermostat housing, am I right? I intend to start by replacing this but is there anything else I should be considering first/aswell? All advice gratefully received. Thanks Quote Link to comment Share on other sites More sharing options...
teabag Posted August 31, 2009 Share Posted August 31, 2009 You have two temperture senders, one behind the distributor with a multi pin plug that's for the engine management and behind that is a smaller sender with a single wire thats the one for the temp gauge. Just disconnect the sender wire (it's a push fit) and earth it, then if the gauge needle deflects when the ignition is switched on you have a faulty sender. Quote Link to comment Share on other sites More sharing options...
