Disco extended bump stops
extreme spain
Help Help! Does anyone know, do extended bump stops exit in the Uk for the D2? I have seen some at Saafrigauard, but they are all the way over in the west coast of America and would work out very pricy!. Its one of the last things I need to finish the Disco and I am off to morocco iat the end of october. Please any suggestions.
Sorry I can't answer your question directly because I don't live in the UK either but I remember once reading that there is a UK company in the North of England who sells the Safari Guard range of gear.
If all else fails....could you not put a spacer under the existing ones?
S.
S.
If only!!!!!!! the Disco 2 bump stops hook intoo the chasis one end and bolt the other, I dont know why they didnt stick to the original set up. :(
