colin tandy Posted September 15, 2009 Share Posted September 15, 2009 hi all just a quick question somethink realy simple is holding me back stripping down my head for a head gasket change on my 300tdi discovery and like most things there is a technique in removing i just cant seem to be able to pull the fuel line off from where it goes from the pump to the injectors !!! just a very simple fuel line is causing me grief... there is no clip holding on it is just on very tight i cant seem to pull off.is there somethink im missing...do i heat it up first ...do i cut it off....how do i remove without damaging or is it a case of get it of and just replace the line after. cheers colin Quote Link to comment Share on other sites More sharing options...
matt bristol Posted September 16, 2009 Share Posted September 16, 2009 http://forums.lr4x4.com/index.php?showtopic=8179 Do you mean the fuel lines from the injector pump to the injectors themselves or the main fuel line form the tank? When I followed the method described in the tech archive it was as easyt as described and I didn't need to remove anythng more than is listed in the guide. don't forget to drain the water out the block before attempting to undo the head bolts - I did and spent hours getting water out of all manner of engines parts! Quote Link to comment Share on other sites More sharing options...
colin tandy Posted September 17, 2009 Author Share Posted September 17, 2009 hi thanks for the reply....yea no worries now sorted wasent looking properly cheers colin Quote Link to comment Share on other sites More sharing options...
