Boro Posted September 21, 2009 Share Posted September 21, 2009 I was under the landrover checking it over for mot, engine running as i was checking exhaust etc at the time and noticed a sort of hissing noise coming from around the engine underneath, it was however irregular rather than constant, anyway i tracked this down to be coming from the threaded hole in the bottom of the gearbox bell housing (timing pin hole) as the noise would disappear when i blocked the hole with my thumb, i never noticed it before now and just want to know whether its normal or whether its a sign of something being wrong Quote Link to comment Share on other sites More sharing options...
cipx2 Posted September 21, 2009 Share Posted September 21, 2009 Sounds like the clutch thrust bearing it's on its way out. Double check that by asking someone else to dip or lightly press the clutch pedal while you listen underneath (or might press the clutch pedal and hear yourself in a quiet environment - like in a garage) and see if noise disappears/diminishes/increases/changes its pitch/etc. If the noise changes then its the thrust bearing. Quote Link to comment Share on other sites More sharing options...
Boro Posted September 21, 2009 Author Share Posted September 21, 2009 Ok will give it a try, its not been used/driven for 4 or 5 months so i suppose it may be that but we shall see Quote Link to comment Share on other sites More sharing options...
cipx2 Posted September 21, 2009 Share Posted September 21, 2009 If it's that and it wasn't driven for the past months, give it some time, drive it day by day for a week, it might come back to normal. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 21, 2009 Share Posted September 21, 2009 If it's been stood for a while then it's likely to have developed a layer of rust on the flywheel. This makes a hissing noise as it's rubbed by the clutch plate. Should go after a short while, otherwise - thrust bearing. Les. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted September 21, 2009 Share Posted September 21, 2009 Hmm, as Boro described it, nobody was dipping the clutch when he could hear the noise. It was just a LR with the engine running on idle and been looked at from underneath. So the flywheel + clutch plate were as one, no relative movement in between, no rubbing between those parts. That is if I understood the whole story correctly. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 21, 2009 Share Posted September 21, 2009 Good point - I never thought of that Les. Quote Link to comment Share on other sites More sharing options...
