freefall1 Posted September 23, 2009 Share Posted September 23, 2009 Hi guys.Would anybody be able to tell me ,How you go about changing the fuel tune id on a 2004 TD5 90 from (svlne 007) to 110 (svloe 005) setting useing a nanocom?,Cheers:unsure: Quote Link to comment Share on other sites More sharing options...
crwoody Posted September 23, 2009 Share Posted September 23, 2009 If you look in the folder where Nanocom is installed on the PC, normally C:\Program Files\Nanocom, you will find a file called - NANOCOM Map Wizard.exe, double click it and it shows a list of map files and related info, select the one you want and press "Generate Nanocom File", it will then ask where you want to save it. Once saved, you can load it to the Nanocom unit and from there transfer it to the ECU. Quote Link to comment Share on other sites More sharing options...
freefall1 Posted September 24, 2009 Author Share Posted September 24, 2009 Thankyou crwoody.I will give that a try. Quote Link to comment Share on other sites More sharing options...
