manxrover Posted September 29, 2009 Share Posted September 29, 2009 Hi All, Can anyone tell me how to remove the unit with the screen, as the lights on the right hand side have gone out. and also removing part of the dash to get at the fuel release switch which has stuck down. Regards Brian Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted September 29, 2009 Share Posted September 29, 2009 'Unit with the screen' I'm guessing to be the one that shows the temperature setting (rather than the Message Centre that is part of the instrument console). The one with the Temperature setting is a combined unit comprising the HEVAC ECU and the control buttons. At the time I wrote the following article I called it the ATC ECU. http://www.rangie.com/articles/71/1589 You will also find a lot of information on the www.RangeRovers.net main site which look in more detail at the bulbs in the switches etc. For the fuel release switch you are looking at removing the Instrument console. Look for articles on changing Blend Motors, as the Instrument Console has to be removed then. As your enquiry reads as though it's your first time ..... Good Luck. Quote Link to comment Share on other sites More sharing options...
manxrover Posted October 4, 2009 Author Share Posted October 4, 2009 Hi Many thanks followed your instructions now all woking fine, just the dash to tackel next Regards Brian Quote Link to comment Share on other sites More sharing options...
