bushwhacker Posted November 25, 2009 Share Posted November 25, 2009 Hi, I am hoping to do the above soon and would like some information before I start. I have had a look on the forum but there does not seem to be much info on this topic. I have changed an 88 truck cab to hard top it was fairly basic so is a 90 similar? Should there be a seal at the roof to the top of the sides, I know there is one at the waist level. Will the truck cab front screen be able to be used with the hard top? Any info will be much appreciated. Quote Link to comment Share on other sites More sharing options...
errol209 Posted November 25, 2009 Share Posted November 25, 2009 I have changed an 88 truck cab to hard top it was fairly basic so is a 90 similar? Pretty much. Should there be a seal at the roof to the top of the sides Yes, and they aren't cheap! Will the truck cab front screen be able to be used with the hard top? Yes. Try not to flex the roof too much when fitting it, as it will then leak (well, more than it did before, anyway ). Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted November 26, 2009 Author Share Posted November 26, 2009 Thanks for the info. Quote Link to comment Share on other sites More sharing options...
