steve_a Posted December 10, 2009 Share Posted December 10, 2009 Just got my 3 Amigos reader and resetter ABS device in the post today from RSW Solutions. Worked exactly as advertised, and at £130 delivered, (A$240) it seems good value rather than dealing with a main service centre and is totally self contained to be left in the car. If anyone has any questions I can try and answer them. The codes on mine are currently inconclusive, since I have had the brake system apart, so some ground faults, relay O/Cs are probably from when the ABS unit was removed and other work was done. Just got to wait for it to come on again and then read the code straight away to see what the issue is. -------------------------------------------------------------- |* ABS Amigo Box V1 RSW Solutions LLC Copyright 2008. *| |* www.RSWsolutions.com *| |* *| |* *| |* Version V1.1 *| |* *| -------------------------------------------------------------- 1.--Current Faults----> Active Faults: None Logged Faults: 040:Pump relay open circuit Front Right Sensor Bad Output 114:Shuttle Valve Electric Failure <-END Faults ------------------------------------------------------------ * * ------------------------------------------------------------ ..--Previous Faults---> Active Faults: 022:ECU Gnd or Reference Gnd bad Logged Faults: None <-END Faults ------------------------------------------------------------ * * ------------------------------------------------------------ ..--Previous Faults---> Active Faults: Comms Error Logged Faults: Comms Error <-END Faults ------------------------------------------------------------ * * ------------------------------------------------------------ Quote Link to comment Share on other sites More sharing options...
