Lenny Posted December 11, 2009 Share Posted December 11, 2009 Hello all, Looking to do a BJ replacement. Please see images of 2 different drop arms. One of the drop arm's upper flange has no "lip/rim"? My original drop arm does has a lip which i assume holds the rubber. Can anyone help? Quote Link to comment Share on other sites More sharing options...
disco_al Posted December 11, 2009 Share Posted December 11, 2009 get a drop arm of a later 300 series disco, and the tie rod from the box to the n/s wheel - does away with the ball joint in the arm, and replaces it with a normal track rod end. Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 13, 2009 Author Share Posted December 13, 2009 Decided to get a big hammer and swapped the droparms. Job done in under 5 mins - before it began to rain too. Quote Link to comment Share on other sites More sharing options...
Pinkrover Posted December 15, 2009 Share Posted December 15, 2009 is this the steering arm ball joint? if it is there is a way of making it last much longer, especially if you wade or go through deep mud. Buy a ball joint replacement kit, lightly score 4 channels with an angle grinder along the axis of the ball and tap a grease nipple into the base plate. Then every time you go off road or wading regrease the ball joint and this will cleanout all the water/carp..... Quote Link to comment Share on other sites More sharing options...
