bill.b Posted July 7, 2020 Share Posted July 7, 2020 4 hours ago, Maverik said: I believe yes it should work if you shorted the rod to 65mm - my rational is thus - I have fitted a 300td to an LT77, we used all the original LT77 clutch gear and it the standard 300tdi flywheel and pressure plate. so if you set up the R380 stumpy ( as standard ) - then that should hook up to a 300tdi too as the LT77/R380 were interchangeable. As Ralph states, its just a bit of an unusual combination hence why you can't find any info on it. Perfect, thank you both. I will give this a whirl and see how it goes. Yes I read this only after I fitted it however :-/..... Anyway, I have high hopes. It’s a good box and should with a bit of fettling work well! I’ll report back. Ignore the gear stick I will flip it, cut it and make another in the shape of the series cheers. Quote Link to comment Share on other sites More sharing options...
bill.b Posted July 7, 2020 Share Posted July 7, 2020 2 Quote Link to comment Share on other sites More sharing options...
Ramp7 Posted February 27, 2022 Share Posted February 27, 2022 This is an old reply but did you move the engine forward? The transmission and transfer case appear in the normal location. Quote Link to comment Share on other sites More sharing options...
