200tdimorgan Posted January 30, 2010 Share Posted January 30, 2010 hi everyone, in need of some advice my flasher unit on my 91 defender went the other day so i have put a new one in, but now when the engine is running it constantly ticks, but the indicators don't flash. i have read someone else had this fault and it was a faulty hazard switch, so i went through the list of ways to test it on Luke's post, but it doesnt seem as though the switch is at fault. when i connect the permanent live to the "supply to flasher", the relay starts ticking fast even though there isnt a feed connecting a supply to the indicators. if i use the indicator stalk then the indicators then work as normal but as soon as i knock them off the relay continues ticking fast. just wondering if anyone has had the problem or knows of how to sort it, where the fault may be cheers Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2010 Share Posted January 30, 2010 probably a fualty flasher unit, try another know good one. Quote Link to comment Share on other sites More sharing options...
200tdimorgan Posted January 31, 2010 Author Share Posted January 31, 2010 well it is a brand new one so i shouldnt think so. i may be able to try the old one if i still have it somewhere. could it be a chafed wire on the way from the flasher unit to the indicator stalk or the hazard switch somewhare? Quote Link to comment Share on other sites More sharing options...
