drkwack Posted February 13, 2010 Share Posted February 13, 2010 Hi, my fuel gauge has stopped working, checked the sender and get a variable ohmm reading as I move the float up and down but no reaction at the gauge, changed the gauage no joy, changed all the clocks no reaction put my sender into another car no reaction, at the wire socket I am only getting 1.8v. so any ideas??? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 13, 2010 Share Posted February 13, 2010 Nope, no ideas. But saying what Discovery is it might trigger some Quote Link to comment Share on other sites More sharing options...
BLACKJACKS Posted February 13, 2010 Share Posted February 13, 2010 looking at the float check the wire on the bottom of the float. and also put a new earth to the the float plug mine wouldnt work and it was a bad earth if i remember theres 2 blck wires its the think one of the 2 is the earth . best of luck .. Quote Link to comment Share on other sites More sharing options...
drkwack Posted February 14, 2010 Author Share Posted February 14, 2010 Hi, sorry forgot its a 300 tdi 96, the wire at the bottom of float is slightly frayed, will try another earth. ta Quote Link to comment Share on other sites More sharing options...
BLACKJACKS Posted February 14, 2010 Share Posted February 14, 2010 same as mine it the wire if you take the float out of the tank theres a little wire resolder a new one . Quote Link to comment Share on other sites More sharing options...
drkwack Posted February 16, 2010 Author Share Posted February 16, 2010 Hi, tried the resolder wire trick didnt work so am begining to believe the sender at least is fubared, might have to call in an auto sparky, ta Quote Link to comment Share on other sites More sharing options...
drkwack Posted February 27, 2010 Author Share Posted February 27, 2010 Hi, update just in case. Time to put hands up and admit I'm a pillo-k, auto sparky mate came out did loads of checks and found the wiring had caught the tailpipe of the exhaust and melted through them, no power return to gauge, new wire inserted and fuel gauge now works. Quote Link to comment Share on other sites More sharing options...
DaveA Posted March 3, 2010 Share Posted March 3, 2010 I was going to ask ... Where did you take the ohm reading, ie at which end of the wire.If you measured the reading at the gauge end of the wire maybe you would have found the fault ?? Ea sy in hindsight ... Quote Link to comment Share on other sites More sharing options...
