DefcoL Posted February 18, 2010 Share Posted February 18, 2010 had to put this up Quote Link to comment Share on other sites More sharing options...
Rich_P Posted February 18, 2010 Share Posted February 18, 2010 Do you think they'll be drawing it in the sands next? Because it won't be "grown in Britain" much longer. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 18, 2010 Share Posted February 18, 2010 I see it even has a fluid leak. Chris Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted February 18, 2010 Share Posted February 18, 2010 Crank rear seal... My mate's got one in his field with the same issue too, common fault on that vintage I believe... Quote Link to comment Share on other sites More sharing options...
Cranberry Posted February 19, 2010 Share Posted February 19, 2010 Where did you get that from / is there a hi-res version available ? Quote Link to comment Share on other sites More sharing options...
DefcoL Posted February 21, 2010 Author Share Posted February 21, 2010 I see it even has a fluid leak. Chris Qualities we will loose if grown elsewhere Crank rear seal... My mate's got one in his field with the same issue too, common fault on that vintage I believe... Cant make out the year but seems to have bulge on bonnet...... are you suggesting leak by deign? Where did you get that from / is there a hi-res version available ? dont know but if you found its location and a high res camara..... send in your shots Quote Link to comment Share on other sites More sharing options...
