yogibear47.lee Posted February 22, 2010 Share Posted February 22, 2010 can you get replacement ones or do you have to go and buy some harden bolt else where is so what the size of them Quote Link to comment Share on other sites More sharing options...
Mark Posted February 22, 2010 Share Posted February 22, 2010 They are available as genuine parts, and aren't that expensive - I don't have the part number to hand though. Otherwise they are 3/8 UNF thread by about 4 inches... I'll try and update with more accurate information later if i get a chance... Cheers Mark Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted February 23, 2010 Author Share Posted February 23, 2010 ok thanks mark Quote Link to comment Share on other sites More sharing options...
Dangerous D Posted February 23, 2010 Share Posted February 23, 2010 LR PN for the bolts is ANR4519. you need 10, price is £1.74 ex vat each. Rubber washers - ANR1504 need 20, price 2.82 ea + vat. 10mm washers - 566580 need 10 - 1.26 ea + vat. Nuts - NY607041L 7/16 UNF need 10 price 0.89 ea + vat. Dave Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted February 23, 2010 Share Posted February 23, 2010 The two central body mounts (inboard of the chassis) are different - you need eight of the type described above. The two I mention are an "eyed" bolt with iirc, a 5/8 unf nut and an unusual stepped bush arrangement. (Applies to 300Tdi) Stu. Quote Link to comment Share on other sites More sharing options...
Mark Posted February 23, 2010 Share Posted February 23, 2010 Incidentally, if you need mounting rubbers, I have a complete set of new ones which are now surplus. I also have a couple of new bolts and nuts as well. Cheers Mark Quote Link to comment Share on other sites More sharing options...
Dangerous D Posted February 23, 2010 Share Posted February 23, 2010 Stu may be right, but I'm just going off the parts cat. Best look at what you have. The earlier chassis supersede to the same as the later type. Dave Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted February 24, 2010 Share Posted February 24, 2010 Sorry, I'm not right There are indeed the 10 body bolts you mention - plus the ones I mentioned. I got loked into there being 10 body mounts, there are actually 12! Front panel Bottom of bulkhead Front outrigger Centre mounts (the eyed ones) Rear outrigger Rear body member Sorry, didn't mean to mislead. Stu. Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted February 27, 2010 Author Share Posted February 27, 2010 cheers for that im not going to start it in till it warms up abit them i will get the parts then Quote Link to comment Share on other sites More sharing options...
