gear stick neutral position
craig
on my 300 tdi the normal position of the gear stick is between 1st and 2nd not 3rd and 4th like nornal, i assume 3rd and 4th is normal??? anyway i have all the covers off as the diff lock lever needs adjustment, is there any way of adjusting the 2 springs which hold the gear stick in its neutral position?
hope this makes sense.......
craig
