andmac Posted March 10, 2010 Share Posted March 10, 2010 hi, just wondered if anyone else has had this problem. i have a td5 disco which has a noise when idling, i have done a bit of digging and when i take a bit of tension off aux drive belt when running the noise goes away, its not a normal belt squeal sounds more metalic, i have checked all pulleys and they seem ok, as soon as i touch the throttle the noise goes away, i am thinking it may be power steering pump, any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
andmac Posted March 12, 2010 Author Share Posted March 12, 2010 i have been told it may be the crank pulley, anyone had any dealings with these. Quote Link to comment Share on other sites More sharing options...
andmac Posted March 13, 2010 Author Share Posted March 13, 2010 its the crank pulley damper, took it off today and rubber is shot, anyone got a good supplier as i nearly fell over when i phoned the dealers. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 13, 2010 Share Posted March 13, 2010 Have you tried the aftermarket guys - Bearmach/Britpart etc, may have a pattern part? Quote Link to comment Share on other sites More sharing options...
