Harald Hansen Posted March 12, 2010 Share Posted March 12, 2010 I've got a Hawkeye diagnostics tool for the Td5, and as the old girl is a bit tired, I had a look at the numbers for the MAF to see if maybe the meter needed replacing (2000 Disco Td5). I took a few readings from a mate's Disco (same year and engine) for comparison: RPM______My airflow___Mate's airflow ___0_________4.4____________4.4 _800_______~42____________~55 1500______~100___________~120 2000______~140___________~170 3000______~280___________~310 4000______~500_______________ Most of the numbers are approximate. The fault log had a "3030 Air flow high" error stored. I tried to get Google to find me some numbers to compare with, but came up empty handed. Any ideas if these numbers are within normal range? Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted March 12, 2010 Share Posted March 12, 2010 Your readings are a bit low,from memory they should be 55-60Kg/hr at idle,330Kg at 3000rpm engine hot all loads off.They do seem to tail off slowly and owners do not realise the power dropping off.Some advocate cleaning them,I rarely have found this to work,nor do cheap aftermarket replacements.If it runs better disconnected then its a sure sign its reading low.If the ecu does not see a high enough reading it simply wont put enough fuel to it to make power. Quote Link to comment Share on other sites More sharing options...
Harald Hansen Posted March 13, 2010 Author Share Posted March 13, 2010 Thanks for the feedback, Ally. On that note, I cleaned the AFM out with both brake and electronics cleaner, and left it overnight to dry out. I got a new set of numbers this morning: RPM______New airflow _800_______~64 1500______~150 2000______~220 3000______~420 So quite a bit higher. I had a test drive, but it was difficult to tell if it translated into increased power, but I'll keep an eye on the MPGs the next weeks. Quote Link to comment Share on other sites More sharing options...
M&S Posted March 13, 2010 Share Posted March 13, 2010 Thanks for the feedback, Ally. On that note, I cleaned the AFM out with both brake and electronics cleaner, and left it overnight to dry out. I got a new set of numbers this morning: RPM______New airflow _800_______~64 1500______~150 2000______~220 3000______~420 So quite a bit higher. I had a test drive, but it was difficult to tell if it translated into increased power, but I'll keep an eye on the MPGs the next weeks. Very interseting, thanks for posting. Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted March 13, 2010 Share Posted March 13, 2010 Very interseting, thanks for posting. I found their to be a difference in output after cleaning one with electical contact cleaner. Didn't last long, but worth it while I waited for the new one. Quote Link to comment Share on other sites More sharing options...
M&S Posted March 13, 2010 Share Posted March 13, 2010 I replaced one last year, as it was faulty. Be interested to know what the readings are in another 1000, the 6000 miles? Quote Link to comment Share on other sites More sharing options...
Harald Hansen Posted March 13, 2010 Author Share Posted March 13, 2010 I'll try to remember and update in a while. I'm keeping an eye on my mileage anyway, as it has been in the 14-15 l/100 km range for a while now. For the record, the breathing for this engine is completely stock. No aftermarket filters, no raised air intake or anything like that. Quote Link to comment Share on other sites More sharing options...
