dottythe90 Posted May 5, 2006 Share Posted May 5, 2006 With the onset of the warm weather, my tax disc holder has cried enough and fallen off the windscreen. Fine - just throw it away and buy a new one I hear you say But why does the old rigid plastic holder have a wire attached to it that disappears off under the dashboard and down into the bulkhead ? I assume its original and factory fitted, so whats it for ? Cheers STEVE Quote Link to comment Share on other sites More sharing options...
Mark Posted May 5, 2006 Share Posted May 5, 2006 Sounds like a stealth mobile phone aerial for a hand free car kit. If there is no car kit still installed, then it will be fine to remove. Dosn't sound facotry at all. My disco has the remnants of about 3 car kits and probably 2 alams in. I am gradually ripping lumps of cable out as I find them! Hope that helps Mark Quote Link to comment Share on other sites More sharing options...
Adesred90 Posted May 5, 2006 Share Posted May 5, 2006 With the onset of the warm weather, my tax disc holder has cried enough and fallen off the windscreen. Fine - just throw it away and buy a new one I hear you sayBut why does the old rigid plastic holder have a wire attached to it that disappears off under the dashboard and down into the bulkhead ? I assume its original and factory fitted, so whats it for ? Cheers STEVE Yes I agree with mark. It is a mobile phone antenna. if you look under the dash you will probably still have a little black box that it connects to. If you do not intend using a hands free kit then dispose of it. if you do, then it might come in useful. Quote Link to comment Share on other sites More sharing options...
dottythe90 Posted May 6, 2006 Author Share Posted May 6, 2006 Yes I agree with mark. It is a mobile phone antenna. if you look under the dash you will probably still have a little black box that it connects to. If you do not intend using a hands free kit then dispose of it. if you do, then it might come in useful. Thanks guys - I'll have a look and remove it Quote Link to comment Share on other sites More sharing options...
