jmattley Posted April 3, 2010 Share Posted April 3, 2010 The cambelt snapped yesterday on my 200tdi, i was doing about 30 at the time and stopped straight away so I didn't drive far with it broken. My question is, will it just be a case of a couple of bent push rods and dented valves or will there be much more damage done to the engine? Cheers everyone!!! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 3, 2010 Share Posted April 3, 2010 If it was the timing (cam) belt, then you wouldn't have been able to drive any distance at all (unless it was rolling downhill) No bent valves, no need to remove the head - just pushrods (about £3 each), a new belt/tensioner/idler/timing cover gasket/timing cover dust seal), and a bit of work. Les. Quote Link to comment Share on other sites More sharing options...
