CBolton Posted April 5, 2010 Share Posted April 5, 2010 Hi all got a small problem, I have finally got my rear subs working I bought for my 200tdi...however my tailgate does not have any of the fixings in the tailgate itself to screw the sub into......all I have are the shaped holes....can anyone tell me what fixings I need ? Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted April 6, 2010 Share Posted April 6, 2010 Im sure on mine they are the metal rivet type nuts? you could also try the round plastic ones that open out from behind, when you insert a screw, But im sure the screws that hold the trim in place are threaded?/so would go with the first. Ian Quote Link to comment Share on other sites More sharing options...
CBolton Posted April 8, 2010 Author Share Posted April 8, 2010 Im sure on mine they are the metal rivet type nuts? you could also try the round plastic ones that open out from behind, when you insert a screw, But im sure the screws that hold the trim in place are threaded?/so would go with the first. Ian cheers getting some rivnuts to do it Quote Link to comment Share on other sites More sharing options...
