davie1 Posted April 7, 2010 Share Posted April 7, 2010 Hi Guys, got a replacement switch panel for the windows, mirrors & sunroof as none worked. The problem now is that they all work except for the drivers door window & mirror. Also when unlocking the car all the doors unlock with the fob except the drivers door which needs to use the key. So basically nothing electrical in the drivers door works. I know I will need to remove the interior panel and it might become self evidant but hoping somebody comes up with some ideas first or has solved this problem before. Cheers & all the best Davie Quote Link to comment Share on other sites More sharing options...
davie1 Posted April 9, 2010 Author Share Posted April 9, 2010 OK, think I found the culprit, looks like the door outstation, will replace & report back. Why oh why do they need to make circuits so complicated plus the outstation would be better out of the door where it is subjected to less shock. Cheers Davie Quote Link to comment Share on other sites More sharing options...
davie1 Posted April 15, 2010 Author Share Posted April 15, 2010 changed the outstation but did not solve the problem, getting power as when unplugging the outstation the other 3 door locks locked & can hear a clicking from the outstation when trying the door mirror. Any advice would be gratfully recieved. Cheers Davie Quote Link to comment Share on other sites More sharing options...
davie1 Posted April 25, 2010 Author Share Posted April 25, 2010 Solved, eventully got time to trace the loom back to the BeCM, found a break in the purple/black wire under the carpet, everything now working. Cheers Davie Quote Link to comment Share on other sites More sharing options...
