deanlr90 Posted April 10, 2010 Share Posted April 10, 2010 Hi hope someone can help.I have a 90 with a LT77 problem, when cold i can't change down from 3rd to 2nd gear all other gears are fine and once warm 3rd to 2nd is much better,almost perfect even.I changed oil[atf dex3]to see if that helped but it didn't.As it is leaking oil from the front output therefore making the clutch slip i will have to do something soon,is it a new box or an easyish fix. Quote Link to comment Share on other sites More sharing options...
