waterloo Posted May 5, 2010 Share Posted May 5, 2010 Had the common problem - rear door wont unlock from the keyfob. Had to pull the chrome lever on the inside (it does lock OK though). Read the forums and bought a replacement return spring (cos they always break dont they!). Dismantled the door - pulled out the actuator and found the spring - in perfect working order - bu@@er. Put everything back together again and the damn thing worked perfectly - at least for two days - now its stopped again and I'm back to where I started. What on earth is going on? Quote Link to comment Share on other sites More sharing options...
Pwyll Posted May 5, 2010 Share Posted May 5, 2010 Dodgy connection on the actuator? Sounds like it's making a reasonable connection when you first plug it in and then failing after a few jolts and bumps. Check the connector and wires leading up to it. Also give the pins a good clean with some emery cloth and a squirt or two of electical contact cleaner if you have some. May not be the answer, but it's a good starting point. HTH, Paul Quote Link to comment Share on other sites More sharing options...
