Andrew Chua Posted May 8, 2010 Share Posted May 8, 2010 Help! When i put the ignition to pos II the fuel pump screams for 3 seconds and later all is well. The thing here is it need the landie for my wedding tomorrow!! it's the bridal car and i don't have the time to drop the tank today and change the pump, which i have. How long can this hold up for? it just started yesterday. Thanks! Andrew Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted May 8, 2010 Share Posted May 8, 2010 Help! When i put the ignition to pos II the fuel pump screams for 3 seconds and later all is well. The thing here is it need the landie for my wedding tomorrow!! it's the bridal car and i don't have the time to drop the tank today and change the pump, which i have. How long can this hold up for? it just started yesterday. Thanks! Andrew It's unlikely to be the pump itself at fault. It's screaming as it's picked up some air in the system, or has become partially blocked with crud from the tank. I'd start by changing the fuel filter - make sure the new one is seated correctly when you do. That'll most likely cure it. Matt Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted May 8, 2010 Share Posted May 8, 2010 Mine made 40.000 kms with really hard noising.... it won't fail for the wedding, don't worry... Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted May 8, 2010 Author Share Posted May 8, 2010 okie cool. Thanks! the pump has already done 166k km. Quote Link to comment Share on other sites More sharing options...
