rab16902k7 Posted May 11, 2010 Share Posted May 11, 2010 hi i have got a problem with my D1 its cuts out when I am stopping, I think it's to do with fuel but can't see where the air it getting in will I be best replaceing the fuel lines for tank to filter and so on Quote Link to comment Share on other sites More sharing options...
crispyme Posted May 12, 2010 Share Posted May 12, 2010 I had a problem with my 300 Tdi where the engine would cut out at random times. Sometimes when I stopped, sometimes when I put my size 11 down hard, sometimes when cruising. Thought it may have been the pump power wire, but that didn't resolve anything. at some point of poking around the engine bay for what ever reason I was there, I unscrewed the bottom of the fuel filter to drain out any carp that may have been in there (assumed water) and, touch wood, I haven't had the problem again. Give that a try. Can't hurt Chris Quote Link to comment Share on other sites More sharing options...
rab16902k7 Posted May 12, 2010 Author Share Posted May 12, 2010 I HAVE DONE ALL THAT TO IT NEW FILTER SEDMENTER STILL NO JOY ITS ITS DOING MY HEAD IN Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted May 12, 2010 Share Posted May 12, 2010 Hi, I don't know if you are aware, but typing in caps is shouting and is considered rude on most internet forums. Some more info on the vehicle would be useful- age/engine type - I'm assuming it's a diesel. Does it splutter and stop - i.e. revs drop to the point that it stalls? Or does it just switch off? Will it start straight away or do you have to leave it for a bit? Quote Link to comment Share on other sites More sharing options...
rab16902k7 Posted May 13, 2010 Author Share Posted May 13, 2010 sorry for caps its a 1996 300tdi the revs drop to under 1.000 then itruns like a bag of nails and cuts out then it will resstart i have checked sedmenter changed fuel filter. and filter on the lift pump i used the bleed screw to get the air out but there is air bubbles in the return pipe comeing from injector going bk to injector pump (the black plastic pipe off injector had snaped so i temp fixed it with a clear pipe ) i hope u guys can help me :( Quote Link to comment Share on other sites More sharing options...
