LRmalawi Posted May 13, 2010 Share Posted May 13, 2010 I have a 2003 disco TD5. The fuel pump has started to spontaneously activate during the night. It has happened on several occasions and only occurs at night - I am assuming this may be to do with the ambient temperature falling. I am in Malawi with no access to engine diagnostics (why have an ecu controlled land rover in this part of Africa i here you say, and i ask myself the same questuion). I therefore have the choice of sendiing the ECU off for checking and having the car off the road for 3-4 weeks (the car is essential for getting around so will need to hire one at considerable expense) or making time to drive down to South Africa (not a short drive). At present I am just pulling the inertia switch fuse at night, but this means i can't secure the car. Is there anything else i could look at before sending off the ecu, i wondered about the fuel temperature sender? It looks OK, can i check this with a multimeter. Any other experiences or thoughts gratefully received. Quote Link to comment Share on other sites More sharing options...
GaryW Posted May 13, 2010 Share Posted May 13, 2010 Are you sure that is is the fuel pump. I had a sond from my car that also sounded like the pump, on closer inspection the sound was preesure in the fuel tank slowly escaping from the breather. I have the V8 petrol. Not sure if you would experience the same with a diesel Quote Link to comment Share on other sites More sharing options...
LRmalawi Posted May 14, 2010 Author Share Posted May 14, 2010 Are you sure that is is the fuel pump. I had a sond from my car that also sounded like the pump, on closer inspection the sound was preesure in the fuel tank slowly escaping from the breather. I have the V8 petrol. Not sure if you would experience the same with a diesel Thanks for reply, definitely the fuel pump, if you turn on the ignition and then switch off you can get the pump to switch off. Quote Link to comment Share on other sites More sharing options...
