stuckinthemud Posted May 23, 2010 Share Posted May 23, 2010 Aircon stopped working recently, worked out it was the high/low pressure cut-out sensor that was disabling the system so assumed that, after 11 years, the system needed a re-gas! One (garage) re-gas attempt with the proper kit, which failed saying the system had a leak. Any suggestions as to where I might start looking? Are there "usual suspects" that cause failures? Thanks Jim Quote Link to comment Share on other sites More sharing options...
