bobthefox Posted May 25, 2010 Share Posted May 25, 2010 Hi all. Bought a nice warn 9.5xp for my defender and done all the mechanical side on sunday. Trouble is... there was no solenoid box mounting plate. Can i just bolt the mounting box to a flat plate, via the 2 bolts on the back, straight onto the chasis, ie. earth it? Or do i need to keep the box "unearthed"? If that's the case, where do i get such a thing? Cheers guys Quote Link to comment Share on other sites More sharing options...
ajh Posted May 26, 2010 Share Posted May 26, 2010 It doesn't matter. Just protect the solenoids from the environment as best you can as the warn ones aren't the most robust. The only concern when mounting things is that the cables be heavy enough for the amperage, which means if you extend them you might need to go bigger depending on how far you go. Quote Link to comment Share on other sites More sharing options...
bobthefox Posted May 26, 2010 Author Share Posted May 26, 2010 It doesn't matter. Just protect the solenoids from the environment as best you can as the warn ones aren't the most robust. The only concern when mounting things is that the cables be heavy enough for the amperage, which means if you extend them you might need to go bigger depending on how far you go. Thanks, mate Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted May 26, 2010 Share Posted May 26, 2010 I have mounted my albright right up at the top of the inner wing next to the washer bottle, out of 99% of the carp...!! Quote Link to comment Share on other sites More sharing options...
