mel Posted July 2, 2010 Share Posted July 2, 2010 Hi All, I'm in need of some advice as i have a problem with the drivers door elec window on my 04 Disco 2. Last week i lowered the drivers window and there was a bang which came from inside the dr. The window seemed to stick momentarily and then lower ok altho when closing it seemed to be slightly out of position as when reaching the top of the frame it seemed to push it fwd slightly but it did close and seemed to work ok . Anyway, i tried not to use it until i could get to investigate it but on Weds i had to lower it and it made a bang again and the glass was lowering and raising but on the tiddle and i had to help it on its way, similar to the old days with wind up window problems! I'm guessing the window has somehow come out of its track but wondered if anyone on here has knowledge of anything similar ? Thank's, Mark Quote Link to comment Share on other sites More sharing options...
Top90 Posted July 2, 2010 Share Posted July 2, 2010 It's probably come off a runner or something needs greasing. Either way, it's a door card off and have a look-see job. Quote Link to comment Share on other sites More sharing options...
boaterboy Posted July 2, 2010 Share Posted July 2, 2010 Mel, it is highly likely that one of the nylon wheels that run in the guides has shattered. Remove the door lining and have a look. See my post Broken Window Winding Mechanism for my and others solutions to the problem if indeed it is a broken nylon wheel. Quote Link to comment Share on other sites More sharing options...
