aldy13 Posted July 6, 2010 Share Posted July 6, 2010 Hi I am just trying to resolve an oil leak from the top of my R380 gearbox and have stripped off the gearchange housing which had no gasket hence the leak, but the I have also stripped apart the lever assembly and as I took it apart the railko bush was fitted first then the oil seal and then the bias adjustment plate. After looking at an exploded view on the internet of the lever assembly it looks like the oil seal fits in the bottom then the railko bush then the bias plate, which is the correct way!!!!!!!!!! Cheers Andy Edit/Delete Message Quote Link to comment Share on other sites More sharing options...
western Posted July 6, 2010 Share Posted July 6, 2010 housing should be sealed with a oil resistant RTV sealant. the very top turret the gearlever fits in has a gasket page 344 item 2 Quote Link to comment Share on other sites More sharing options...
aldy13 Posted July 6, 2010 Author Share Posted July 6, 2010 mine is not like that its a 300tdi discovery box Quote Link to comment Share on other sites More sharing options...
western Posted July 6, 2010 Share Posted July 6, 2010 Now if you had mentioned what vehicle in your original question, I wouldn't have got it wrong & this is been moved to the Discovery forum. Quote Link to comment Share on other sites More sharing options...
aldy13 Posted July 6, 2010 Author Share Posted July 6, 2010 Sorry but it has been retrofitted into a 90 (badly I might add) Quote Link to comment Share on other sites More sharing options...
