piper109 Posted July 26, 2010 Share Posted July 26, 2010 On the non EDC injector pump used on 300tdi there is a lever on the back side of the pump which is attached to the throttle arm via a couple of springs. The throttle cable passes sort of through it. Can someone tell me what it is for? How should it be adjusted? I had the top off the pump to replace a throttle shaft seal and saw what it does. Most of the time I think it does nothing at all. What German trickery am I trying to fathom out? Is it an emergency shut down lever? Or maybe part of an anti-shudder system? I had thought it was part of a cold start system but its not that. Thanks, Steve Quote Link to comment Share on other sites More sharing options...
mayur Posted July 28, 2010 Share Posted July 28, 2010 hi i have a leaver on the side of my pump that attached by a spring (but moved by the throttle)it looks like it adjusts the gorvener or fueling system to add more fuel to when trying to rev up the engine Quote Link to comment Share on other sites More sharing options...
