bangbang Posted July 29, 2010 Share Posted July 29, 2010 still having problems with the misses freelander it's no started cutting out on her and as you can't stall a desil i'm thinking it has to be electrical some one has mentioned the remodification ecu through to the fuel rail pressure sensor that could be at fault and land rover has modified the loom and a pressure regulator has and one had problems with this or had it done or any more info would be gratefully recieved atb Dave Quote Link to comment Share on other sites More sharing options...
Llanigraham Posted July 31, 2010 Share Posted July 31, 2010 Start with the simple things.......check that the switch on the back of the ignition barrel is working correctly. Quote Link to comment Share on other sites More sharing options...
bangbang Posted July 31, 2010 Author Share Posted July 31, 2010 thanks and will do Quote Link to comment Share on other sites More sharing options...
