Ratty43 Posted August 18, 2010 Share Posted August 18, 2010 Hi all, I went for my MOT yesterday and apart from yet more welding and a hub seal that sprang a leak on the way to the garage the only other fail was that the near side hazards aren't working. When I got back I had a quick play and found that they come on if the indicator switch is moved one way or the other, they continue to work if the switch is then moved back to the off position. Any ideas as to the cause would be most welcome. Thanks in advance, Ratty. Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 18, 2010 Share Posted August 18, 2010 Hi all, I went for my MOT yesterday and apart from yet more welding and a hub seal that sprang a leak on the way to the garage the only other fail was that the near side hazards aren't working. When I got back I had a quick play and found that they come on if the indicator switch is moved one way or the other, they continue to work if the switch is then moved back to the off position. Any ideas as to the cause would be most welcome. Thanks in advance, Ratty. A loose/broken wire or bad contact in the hazard switch: green/red is LH inds, green/white is RH inds, so whichever doesn't work. Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted August 18, 2010 Author Share Posted August 18, 2010 Brilliant, thanks very much errol. Quote Link to comment Share on other sites More sharing options...
