speedemoneire Posted September 3, 2010 Share Posted September 3, 2010 Do you think white smoke at start up is a severe problem. Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted September 3, 2010 Share Posted September 3, 2010 Is it a petrol or a diesel? If diesel then it's likely to be low temperature stopping the fuel being burnt, faulty glow plugs would be a place to start or the pre-heat system. Could also be condensation in the exhaust, you should be able to tell if it's steam or diesel by the smell. Quote Link to comment Share on other sites More sharing options...
speedemoneire Posted September 3, 2010 Author Share Posted September 3, 2010 Its diesel the smoke is at every start even when warm and lasts 2 mins. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted September 5, 2010 Share Posted September 5, 2010 White smoke at cold diesel engine start is common as per Ratty43 post. In that case it is unburnt fuel. Unburnt diesel from a warm engine could occur if compression is poor or injectors aren't atomising properly. White smoke can also be water vapour - leaking gasket or cracked head. Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted September 5, 2010 Share Posted September 5, 2010 Odd that it should be at every start and only for a short period, do you have any other symptoms to go with it? Quote Link to comment Share on other sites More sharing options...
speedemoneire Posted September 6, 2010 Author Share Posted September 6, 2010 Odd that it should be at every start and only for a short period, do you have any other symptoms to go with it? No sorry i dont i susspect its the injectors is this a big job its a 1985 straight 2.4 diesel Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted September 7, 2010 Share Posted September 7, 2010 You might see if it's dodgy spray pattern from the inectors courtesy of any erosion of the ends of the glow plugs. I's a case of whipping out the old and putting in new ones so pretty minor. Quote Link to comment Share on other sites More sharing options...
uganda110 Posted September 20, 2010 Share Posted September 20, 2010 Injector testing is a great idea. Did you ever give it a try? I'd also pull the hose on the top of your intercool and see if there is any oil in it. If so, it could just be burning oil from the intercooler. You may have a failing turbo or a bad engine breather. Quote Link to comment Share on other sites More sharing options...
