injectors
Do you mean the 2.5 N/A or TD engine?
If so, then yes, remove injector pipe, spill rail connection, then the two nuts that hold the injector to the head. You may have to apply some leverage to the injector to get it out. There are also 2 x washers that need to be replaced to prevent leaks.
These injectors can be repaired by a diesel specialist, but are quite cheap to buy - either recon or new.
Les.
