speedemoneire Posted September 10, 2010 Share Posted September 10, 2010 is it hard or expensive to change the injectors on a 2.4 diesel straight 1985 landi mine is smoking white and i think its them Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 11, 2010 Share Posted September 11, 2010 Do you mean the 2.5 N/A or TD engine? If so, then yes, remove injector pipe, spill rail connection, then the two nuts that hold the injector to the head. You may have to apply some leverage to the injector to get it out. There are also 2 x washers that need to be replaced to prevent leaks. These injectors can be repaired by a diesel specialist, but are quite cheap to buy - either recon or new. Les. Quote Link to comment Share on other sites More sharing options...
speedemoneire Posted September 12, 2010 Author Share Posted September 12, 2010 its a 2.5NA sounds simple enough now to find time to do it. Quote Link to comment Share on other sites More sharing options...
