Debs. Posted November 7, 2010 Share Posted November 7, 2010 I`m fitting a single electric fan instead of the viscous unit; simply connected with a relay, fuse and a thermo-switch with a manual toggle-switch as a bypass/over-ride and test-check. The obvious way to directly sense the circulating water temperature, would be to replace one of the vent plugs with an appropriately-threaded thermal switch. There`s both plastic (on housing) and brass (on radiator) vent plugs; are they the same thread and does anyone know which is their thread type and pitch?.....Knowing that will help greatly at the motor factors. Thank you, Debs. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted November 7, 2010 Share Posted November 7, 2010 IIRC....its 1/2"BSP....nothing special Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 8, 2010 Share Posted November 8, 2010 IIRC they are the same and X-Eng make a decent replacement. My LSE has an afermarket rad with a differnet fitting so worth checking first. If you don't have air conn the thermostat elbow has 2 temp switches in it, or Wizard sells a decent adjustable switch with a capiliary that goes into the top hose. For a bomb-proof sealed solution again see X-Eng. Another alternative, some manufacturers had "dry" switches on their radiators held on with a clip, can't remember who but a mate fitted electric fans to a classic car with one. Quote Link to comment Share on other sites More sharing options...
Debs. Posted November 8, 2010 Author Share Posted November 8, 2010 Thanks for the replies, chaps: I`ll probably go for the easiest and cheapest way and simply use a 1/2" BSP threaded thermo-switch replacing the brass vent in the radiator. Quote Link to comment Share on other sites More sharing options...
