seth's dad Posted November 16, 2010 Share Posted November 16, 2010 could any body tell me if the alternator from a 19j engine will fit on the disco 200tdi thats soon to be swapped over onto my 110, engine was missing the part when i bought it and i dont want to buy one if necessary Quote Link to comment Share on other sites More sharing options...
ady 1 Posted November 16, 2010 Share Posted November 16, 2010 hi seths dad. yes it will fit. but you might have to undo the three bolts that go through the alternator and rotate it so that tension bracket is in the right place. plus you might have to alter wiring depending on what your 110 engine harness has on it.i had to do this when i put a disco engine in mine.hope this helps Quote Link to comment Share on other sites More sharing options...
seth's dad Posted November 16, 2010 Author Share Posted November 16, 2010 thanks for the quick reply, about time it left some money in my pocket, the wife can stop naggin now Quote Link to comment Share on other sites More sharing options...
ady 1 Posted November 17, 2010 Share Posted November 17, 2010 thanks for the quick reply, about time it left some money in my pocket, the wife can stop naggin now hi seths dad. when you come to do your alternator.when you remove the 3 bolts DO NOT TAKE APART just rotate the alternator so the hole that you use for the belt tension is in the right place.and check wiring at alternator end it might need changeing.ps hope your wife has stopped nagging mine is the same ? Quote Link to comment Share on other sites More sharing options...
