badger 12 Posted November 28, 2010 Share Posted November 28, 2010 Hello all, just trying to find descriptions for faults on airbag suspension readouts. My 93 RRC sat for 2 weeks & when started the airbag system was in fault, 1 F82 Hidden 7 Vehicle has moved.I was able to reset via laptop but am not sure exactly what these faults mean Can anyone help me with a full description. Regards Barry Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 30, 2010 Share Posted November 30, 2010 What sort of diagnostic system have you got then? did it come with any code lists. I use Rovacom and although it's expensive it's very useable with clear diagnosis and help files. Common problems include height sensors wearing and going "out of range" due to drop-outs in the resistor track, pump faults and leaks. If the car doesn't rise in a fixed time it will go into fault mode, if a ride sensor.road speed signal fault develops it will run in fixed height (standard) mode. Quote Link to comment Share on other sites More sharing options...
badger 12 Posted December 1, 2010 Author Share Posted December 1, 2010 I have a free program downloaded from the internet called EASunlock. After making a cable from the laptop to the vehicle as designed by the program designer 'www.rswsolutions.com'.It may not be as sophisticated as a Rovacom, but will read faults, reset faults, and calibrate ride heights. Since my first post I have received more information on the program and what I need to tweek and a fault list 'www.rswsolutions.com/index.php?option=com_content&view=section&layout=blog&id=8&Itemid=62'. If you wish check it out and give me your opinion. I appreciate your reply. Regards Barry Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted December 2, 2010 Share Posted December 2, 2010 Tried that web address and it seemed to be in spanish, the only bit of English I could see said something about an ABS signal to the EAS ECU. That I'm afraid is rhubabrb, the ABS and EAS are not connected as far as I know, the EAS gets its information about road speed from the road speed signal buffer, along with the speedo and the cruise control. Quote Link to comment Share on other sites More sharing options...
