rmtucker Posted December 26, 2010 Share Posted December 26, 2010 Ok i bought a 1991 Discovery about 12 months ago. Ever since i bought it,there has been a terrible whining from the gearbox. The whining seemed to get worse in 3rd,4th,5th. It has never been a problem till today. I took the wife and daughter out for a bit fresh air today in weardale,whilst out the gearbox started to make a scraping noise while travelling slowly,just like grit in a disc brake if you know what i mean?. Anyway for the next 5mins there was all kinds of grinding and scraping. I switched the transfer box into neutral and the noise stops. But if i re-engage the tranfer box and the normal box it all comes back After that it has now settled down to a nasty whining and scraping,but managed to drive the 10miles back too crook without and major mishaps. My question is this, Should i just try and find a replacement box and transfer box? Or is it something i can repair? maybe an easy to reach bearing. Oh and a merry christmas too all. (Bah Hum Bug). Forgot to mention 200TDI Quote Link to comment Share on other sites More sharing options...
pinny Posted December 26, 2010 Share Posted December 26, 2010 my disco ive had for 4 years now replaced the clutch last july the end of november it started being a pain to change gear or select gears whilst driving home one night i could only select 2nd gear and the noise grinding was getting worse after taking box and transfer box out i found it to be the input shaft bearing ,also most of the splines had been chewed out on the out put shaft i picked up a second hand box and transfer box for 200 quid and so far shes running better than ever chris Quote Link to comment Share on other sites More sharing options...
