Igol Posted January 8, 2011 Share Posted January 8, 2011 Now what? I’ve just gone out on a test drive after replacing my front wheel bearing on my 97 Disco. Front end seems fine but as I set off there was a horrible noise a selection of grinding and squeaking from the back end of the car. ABS light is also stuck on, I had assumed that this was to do with the front bearing as it came on when that went. Jacked her up and rear bearings are both fine no play at all. I’ve jumped up and down on the tow hook and suspension seems fine and the noise doesn’t get any worse when you go over pot holes/speed bumps. I’m now thinking something to do with the brake callipers and checked to see if the pads have dropped through the calliper but there’s no scoring on the hub any other suggestions more than welcome. Quote Link to comment Share on other sites More sharing options...
