2.25P block question.
msggunny
This 2.25 petrol block i inherited has a hole in the partition between the water passages. Its kind of hard to tell from the picture but if you look closely just past and on the top corner of the casting plug you can see a black hole with silver blob sides.
Everyone here i have asked cant seem to tell me if its benign or the making of a catastrophic overheating failure later down the road.
Any ideas? Anyone seen something similar?
Thanks.
For reference, its the upper right passage coming from the water pump.
Two different perspectives.
You can see light through the hole when you put a torch on the closest water passage to it in the block.
